EGR valve????
Old Sep 4, 2005 | 06:37 PM
hisame2332
EGR valve????
Hi,
How long can I keep driving w/ my check engine light on (caused by EGR
valve) on a 1998 honda prelude??? Is the EGR valve that important??? any
assistance would be tremendously appreciated...
thanx in advance...
jim beam
Re: EGR valve????
hisame2332 wrote:
> Hi,
not very long. pull the code and determine the exact problem. if
you've already done that, post the code along with your
question!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
yes, it regulates emissions and reduces combustion temperature. that in
turn reduces oil consumption & extends the life of "hot" components like
exhaust valves.
> any
> thanx in advance...
Old Sep 4, 2005 | 07:49 PM
hisame2332
Re: EGR valve????
Hi,
I'm not sure what the code exactly looks like... but the guy at Autozone
gave me a ticket that reads, "Wells... EGR4045... O.E.M. #18011-P13-00"
Does this mean that I have to change the entire valve or just the
gasket???
thanx again...
Old Sep 5, 2005 | 01:30 AM
Steve H
Re: EGR valve????
What engine?
Some 2.2 Honda's clog the passages and cause egr problems, not a big fix and
cheap too.
Stephen W. Hansen
ASE Certified Master Automobile Technician
ASE Undercar Specialist
http://www.troublecodes.net/
"hisame2332" <hisame2332@yahoo.com> wrote in message
news:994190c6fbb72f90bc483946e838c6ac@localhost.ta lkaboutautos.com...
> Hi,
> thanx in advance...
Old Sep 5, 2005 | 10:36 AM
TeGGeR®
Re: EGR valve????
news:ded7c9534a958025ec12e6c3f3cad3fc@localhost.ta lkaboutautos.com:
> Hi,
> Autozone
> #18011-P13-00" Does this mean that I have to change the entire valve
> or just the gasket???
> thanx again...
You're going to have to be more careful in your reportage. That code is
invalid.
Valid standard EGR codes:
P0401 Exhaust Gas Recirculation (EGR) Insufficient Flow
P0404 Exhaust Gas Recirculation (EGR) Control Circuit Range/Performance
Problem
P0406 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High
Voltage
Valid enhanced EGR codes:
P1491 Exhaust Gas Recirculation (EGR) Valve Insufficient Lift
P1498 Exhaust Gas Recirculation (EGR) Valve Position Sensor Circuit High
Voltage
P2413 Exhaust Gas Recirculation (EGR) System Range/Performance Problem
TeGGeR®
The Unofficial Honda/Acura FAQ
www.tegger.com/hondafaq/
Old Sep 5, 2005 | 01:32 PM
hisame2332
Re: EGR valve????
Hi,
Sorry about that... I believe the code is "P0401"... should I replace
it or should I clean it??? Is the latter pretty simple to do or should I
just go to a mechanic???
thanx again...
Old Sep 6, 2005 | 02:53 PM
shaolin's Avatar
EGR is important.
it is emission related so if your EGR not working right than i think your car will not run right.
EGR sents the exhaust gas back to the combustion chamber to reduce nox.
Steven Hung
16
Feb 17, 2019 03:42 AM
codenamezero
Sep 21, 2016 08:23 AM
contagiouss_blue
May 23, 2015 09:07 PM
Lamak
Mar 15, 2009 03:24 AM
Darellbrownnose
May 18, 2005 11:20 PM
