Looking for some passing power--bolt ons?
I drove two R56 S and 2 R56 Standard mini coopers. I would say gearing in the regular was just ok. The S had a lot more grunt to it and seemed to have slightly different gearing--bit better acceleration--could've been the turbo though.
I haven't had a lot of behind the wheel time on the fit yet--I'm sure on Monday night my opinion will be a lot more fleshed out. It's going to be a 45 minute drive back from the dealer.
Oh I see and agree there... Honda needs to bring the Fit RS's 6 speed over state side as standard or optional equipment. -.-
The Fit will behave very similar to a just-a-Cooper though despite the difference in rear suspension and being a larger vehicle. Affectively speaking for the Fit there are 3 "types" of transmissions; the 5 speed auto without paddles (Base only), the 5 speed auto with paddles (Sport only), and the 5 speed manual (Base and Sport). Both auto transmissions are basically the same, just the Sport has paddles to upshift/downshift when the driver wants so long as the engine doesn't bog itself or go to close to redline. This comes in handy a lot for hilly roads and passing.
I live in the Chicago suburbs, Ironically 75% of the drivers here take pleasure in being dicks and preventing passing or even merging. If you ever end up on 290 going into Chicago and pass the Manheim exit it slows down to a crawl because people refuse to allow merging--really the most insane driving/traffic I have ever seen.
The "two" places I avoid like the plague are: downtown Chicago... and near O'hare airport.
But even so... there are asshats everywhere.
Even at 2 in the morning when you're cruising along the highway just to get home at decent 75 mph... some fucker behind you will fly down the highway from seemingly nowhere, pull in front of you... and brake.
It doesn't matter what lane you're in... or how many exits you pass with the a-hole in front of you. The moment you try to pass... he takes off in an effort to not let you pass.
And this is considering you're the only two cars on a three lane expressway.
I live up in the northern burbs.
Mini Cooper (2012 Automatic without S package)
Torque - 114 @ 6000
Horsepower - 121
0-60 - 9.6
1/4 Mile - 17.2
Honda Fit Sport 2012 with Automatic Transmission
Torque - 106 @ 4800
Horsepower - 117
0-60 - 11.4?/10.2 --consumer reports/insideline.com
1/4 Mile - 18? --seems like this should be less high even for an automatic
Not even gonna post for the Saturn SL2--On paper it's faster than both of the posted cars but I think thats all BS, once a car has that many miles it's a crap shoot.
Torque - 114 @ 6000
Horsepower - 121
0-60 - 9.6
1/4 Mile - 17.2
Torque - 106 @ 4800
Horsepower - 117
Oh yeah, and the car I'm buying is a 2012 Sport Automatic--been trying to find someone dumb enough to let me learn to drive stick in there car for a few years.[/QUOTE]
I've got a 2012 sport AT as well now for about 2 months. It's awesome! Get rid of the stock filter out and put in a K&N filter. It feels like the engine can breath again.
When you pick up the car do an ECM idle reset procedure.
Get a Electronic Throttle Controller.
Automatics are great in town.
Some other mods I did that you can do are
JDM rear wiper blade mod
and
Shark fin antenna
Have fun with your new toy, I am!
and
Shark fin antenna
and
Shark fin antenna
Have fun with your new toy, I am![/quote]
You are talking about the drop in filter right? I was thinking of doing that anyway.
K&N drop ins are a bit of a waste in my honest opinion.
Yes, they are reusable and allow more air flow due to having larger pores in the filter material allowing more air (and dirt) to flow through. However, the user has to make sure that the filter is dry enough after being cleaned or risk having the oil from the "recharge"/cleaning kit drip onto the MAF sensor, causing it to give false readings.
Companies like AEM and AFE however do have reusable, dry flow filters that do not require any oiling what so ever to be used. Just wash it off, make sure its dry, and go. AFE produces reusable dry flow filters that are compatible with the factory air box, AEM only produces reusable dry flow filters on short ram and cold air intakes.
If one were to have an aftermarket intake (be it cold air, short ram, custom, etc.) and/or have an aftermarket air filter that doesn't meet the vehicle manufacture's specifications installed in a vehicle that is the verified cause of a vehicle malfunction, then the warranty on that repair can be voided. Again, the part HAS to be the CAUSE of the issue in order for the warranty to be voided in a repair that a vehicle should be covered for in the case of aftermarket parts. This is covered under the Magnuson Moss Warranty Act.
#32
Be aware though that up here in Canada and the rest of the world for that matter....the warranty act doesn't apply. Always remember Fit Freaks are worldwide baby!
Off to vacuum my baby.
#33
I don't imagine there being any problems with a filter. This is on down the road stuff anyway--I want to get the car, break it in and probably drive it till the warranty is off before I'd even consider doing anything to it.
#34
best bang for the buck power for the fit sport for passing power?
Use Shell V power gas and paddle shifters are your friend.
too bad the Canadian fit sport doesn't have the paddle shifters, that's why I drive a US model fit sport
#35
The brand or type of gas used will have NO effect on power production. The Fit is designed to use 87 octane fuel. No benefit will come from using a higher octane. Using a quality brand is wise, as is going to a station that has newer tanks and pumps. The tanks will have less sediment in them, and the newer pumps will have the best possible filtration abilities.
A good drop-in air filter will free up a small amount of power. Not much, but it's one of the few things you can do that won't have any negative effects. I'm going to be looking into the AFE drop-in myself. I hadn't heard of that brand until this thread, and it interests me! Thanks, Hootie!
The L15A is a very efficient motor as it is. Any increases in power with minor bolt-ons are going to be minimal. If you allow for too much airflow, especially in the exhaust/header, you may see your powerband pushed into the upper RPM limits, even more than it is now (I've noticed that my Fit doesn't really come alive until about 4k RPM) If you want good response, putting the powerband up over 5k RPM is not a great thing to do, unless you're prepared to rev the crap out of your engine every time you want to go somewhere fast!
Proper maintenance, a good tune up (a pain in the ass with the spark plugs being practically inaccessible!), and carrying as little excess weight as possible will give you the most passing power.
Larger, wider wheels may actually make you a bit slower, as you'll be adding unsprung weight and rolling resistance. I had 16x7 Konig Torque wheels on my car for a short time (until I broke one), and I noticed that while the car felt more stable, it had a "zippier" feel with the skinny stock 15" steelies on it. I'm back to steelies, and staying there.
As said above learning your car is the best option of all. Our little engines aren't going to produce much power without SERIOUS modification, so being aware of your environment and your car's capabilities will work to your advantage. Downshift to a lower gear (for those with manuals, or at least paddles) to get your RPM up over 4000. That seems to be where the Fit makes enough power to get out of its own way.
#37
[quote=deevergote;1100956]The brand or type of gas used will have NO effect on power production. The Fit is designed to use 87 octane fuel. No benefit will come from using a higher octane. Using a quality brand is wise, as is going to a station that has newer tanks and pumps. The tanks will have less sediment in them, and the newer pumps will have the best possible filtration abilities.
are you kidding me????? he's looking for some extra passing power, obviously anytime you use a HIGH octane fuel that is 100% gas no ethanol your engine will run better and produce more power.
Shell V power gas is 100% gas from oil, no ethanol crap, you will notice power increases on the highway and increased fuel economy guaranteed,.
It will be noticeable especially on the highway.
FOr those who haven't tried it, I suggest you do.
#38
#39
yes, lets not, you're one of those guys that probably thinkgs the 5MT gets better mileage then the 5AT too eh?
anyways, i know a lot about engines, and basic performance and I have owned 11 fits from 2009-2012 and definitely notice the difference in premium gas on the highway for the fit, but each to their own.
#40
I won't argue. I said my bit, you said yours. People can believe whatever they wish. I won't resort to tossing around insults based on uneducated assumptions.
I would be very interested to see a dyno test that supports either your claim or mine, though.
