Keyless Entry on Base Model
Old 01-06-2010, 10:31 AM
cflhonda's Avatar
Former Vendor
Sounds Good!
FITunion,
We are still offering the free shipping. Please keep in mind it will be shipped USPS so shipping might take 3-5 Days. I appreciate the support on here and if you guys need anything from a video to a write up let me know and I will get it done for you.
Thanks,
Dan@CFLHonda
  #142
Old 01-06-2010, 11:01 AM
cflhonda's Avatar
Former Vendor
Hey guys just some FYI, the key it self has a chip that needs to be programmed to the car in order for the key to start the car. The remote can be programmed by yourself if you follow the steps listed in this thread.
robert @ cflhonda.com
www.cflhonda.com
  #143
Old 01-07-2010, 01:46 AM
Chazzlee's Avatar
www.cflhonda.com
ON my CFL-purchased Sport model key I cut the metal key part of it off and smoothed the edges down with a Dremel, and just kept the top button part. I use it on a key ring along with my Base key; no problem, and very easy to self-program!
I also purchased the keyless button fob from CFL (which is smaller), and this my wife uses on her key ring along with her Base key.
I just didn't see any reason to get any key chips re-programmed, as I prefer having the smaller Base key for the ignition and having a separate button gadget for keyless entry anyway.
(It's also cheaper that way too, although that really wasn't my main consideration...)
  #144
Old 01-07-2010, 04:28 PM
cmj912's Avatar
I just got my key cut and the immobiliser chip programmed this morning.
Works wonderfully, and I'm overjoyed to have keyless again.
Interestingly, when I brought the car in the tech did ask me where I'd gotten the key, since he wanted to "make sure I had the right one because they are all different".
Well, that's not *exactly* true because according to College Hills both the Fit Sport key with integrated fob and one of the keys for the CR-V can be cut and programmed to work in a Fit Base.
All I said - out loud - to him was that on my receipt the part number was a key for a Honda Fit. He accepted that explanation and everything was fine, but I guess I just didn't want to "out" everyone that is trying to do this less expensively.
Like someone else had mentioned, dealers could attract some business if they offered this service as a 'deal' on the QT but I guess maybe they are hoping that the bulk of the customers would be none the wiser and would just pay whatever is asked when they buy the car if they want it.
Eh, still saved me some money over purchasing the "keyless entry option"...now if only the glovebox USB self-install were just as easy.
  #145
Old 01-10-2010, 11:33 AM
stockrex's Avatar
ok I received the keys (thanks a bunch Dan)
so I just take em to honda to
1. Cut
2. chip programmed
that is it? and the door will open close? I can't believe that it so simple?
so what the heck is the keyless thinggy they are selling?
  #146
Old 01-10-2010, 11:37 AM
Steve244's Avatar
1. Cut
2. chip programmed
a rip-off.
  #147
Old 01-12-2010, 12:30 AM
FITunion's Avatar
I got the fob from the mail tonight. Got the silicone cover yesterday. Sat in the fit for less than 15 seconds, the car instantly upgraded with keyless entry. I'm amazed how easy it really was.
Thank you Dan for the key fob. Wonderful doing business with you.
  #148
Old 01-12-2010, 01:15 PM
cflhonda's Avatar
Former Vendor
Sounds Great! No more fumbling through your keys to open your door.
Dan@CFLHonda
  #149
Old 01-29-2010, 09:30 PM
alexpb's Avatar
72147-swa-a01
I bought 72147-SWA-A01 from cflhonda.com. It works fine, but it looks like it is missing the case. I had to drill a hole to be able to add it to my keychain and I also had to glue it together so it wouldnt come appart so easily (hopefully the battery will last for a while because I won't be able to replace it).
it looks like this: http://www.tinaparsadanov.com/igor/IMG_5730.jpg
it is missing the case shown here: http://i301.photobucket.com/albums/n...Mar2009013.jpg
  #150
Old 01-29-2010, 09:35 PM
Steve244's Avatar
That "case" is the key itself, with the metal key part sawed off (you can see the metal nub peaking at you on the left side). Honda doesn't make a separate case for it as they only market a remote entry key.
Some enterprising individual will sooner or later no doubt.
  #151
Old 01-29-2010, 09:36 PM
Take a look at the pics I posted in my profile. I have the same remote, mounted it to a piece of plexi, then used a rubber cover they sell on eBay..I think it looks good and it has works fine..
  #152
Old 01-29-2010, 10:20 PM
alexpb's Avatar
I decided to buy a key case off Ebay:
HONDA REMOTE KEY REPLACEMENT CASE 3button+panic (HONDA REMOTE KEY REPLACEMENT CASE 3button+panic : eBay Motors (item 140376843815 end time Feb-21-10 15:39:53 PST))
even if the FOB only has 2 buttons + panic... it looks like it's going to fit.
  #153
Old 02-12-2010, 09:57 PM
jackie11111's Avatar
Thanks, CFL Honda!
Here I am enjoying my $35 keyless entry, with a beer and my cat. Life is good.
  #154
Old 02-16-2010, 12:10 PM
vze29tgr's Avatar
I plan on adding keyless entry to my 2010 Base Fit. I plan on ordering 72147SWAA01 from Dan. I understand this is just the fob. Do I use my current keys to program the fob for keyless entry? How does this work since I do not need another key and just want the fob. Thanks in advance.
  #155
Old 02-16-2010, 09:57 PM
red600's Avatar
All you need are the fobs you're going to use with your car and one of your Fit keys. Follow the instructions on this video. The fob part you're buying is the circuit board that's removed from the key in the video.
YouTube - chhonda's Channel
  #156
Old 02-17-2010, 03:51 PM
rainbowjersey's Avatar
Just bought a 2010 base Fit. Just want to confirm all I need is the new fob and then follow the process outlined within this thread to program it and all will be good?
Thanks
  #157
Old 02-22-2010, 12:20 PM
vze29tgr's Avatar
Thanks
Yes it will work. I just got my fob and followed the youtube video and it works perfect.
  #158
Old 02-27-2010, 01:10 AM
Irish4199's Avatar
Wanted to note that purchasing the key (College Hills) was more complicated than "synchronizing" it with the car. Add in 3 minutes with a Dremel, and voila! GREAT GREAT GREAT FIX, thank you guys so much! $40 compared to the ~$300 the dealer wanted. (And I remember him saying "might as well go for the remote starter at that point....only an extra $200"). Can't believe those guys....
  #159
Old 02-27-2010, 06:37 PM
derf's Avatar
Just ordered from cfl
  #160
Old 03-04-2010, 08:57 AM
cflhonda's Avatar
Former Vendor
Glad to see everyone is satisfied with the keys. Please Please make sure in the comment field you mention your from fitfreak so that I can make sure the shipping is FREE. Thanks again for all your support.
Dan@CFLHonda
1.800.572.7926
WWW.CFLHONDA.COM
Quick Reply: Keyless Entry on Base Model
